Akasa AK-15-NSBLPC Blue Neon String 150cm - Internal Kit 1 £7.99 (£7.99)
Akasa AK-178-RD 12" Cold Cathode - Red 1 £7.99 (£7.99)
OcUK GeForce 8800 GTX 768MB GDDR3 HDTV/Dual DVI (PCI-Express) - OEM 1 £269.99 (£269.99)
Thermaltake VE2000BWS Armour LCS Super Tower - Black 1 £123.99 (£123.99)
OCZ GameXStream 600w Silent SLI Ready ATX2 Power Supply 1 £49.99 (£49.99)
Samsung SH-S183ABEBN 18x18 DVD±RW Dual Layer Serial ATA ReWriter (Black) - OEM 1 £17.99 (£17.99)
Western Digital Caviar SE16 500GB 5000AAKS SATA-II 16MB Cache - OEM 1 £56.99 (£56.99)
Asus P5K Deluxe WiFi Intel P35 (Socket 775) PCI-Express DDR2 Motherboard 1 £124.99 (£124.99)
Intel Core 2 Quad Pro Q6600 "LGA775 Kentsfield" 2.40GHz (1066FSB) - Retail 1 £149.99 (£149.99)
City Link Parcel Next Day (Delivered Mon-Fri): £12.95 (£12.95)
Order Total: £966.86 (£966.86)
so guys as you can see, ive gone with a cheaper and easier option of the thermaltake case + water cooling combo. Im not so sure anymore i should have done some research before hand but all the other components were my main priority
however if i do overclock it will be my first attempt i dont think i will need too but i might give it a go. so will this thermaltake system be able to keep my chip under 45-50 on load? if not please spec me a watercooling system able to keep my chip really cool. thanks and will i be able to cancel the thermaltake Armour LCS case order, it's still at their warehouse que apparently.
p.s i do have a little expereince with watercooling, i have a zalman reserator keeps my p4Ht 3.4 at 50 on load.
however if i do overclock it will be my first attempt i dont think i will need too but i might give it a go. so will this thermaltake system be able to keep my chip under 45-50 on load? if not please spec me a watercooling system able to keep my chip really cool. thanks and will i be able to cancel the thermaltake Armour LCS case order, it's still at their warehouse que apparently. p.s i do have a little expereince with watercooling, i have a zalman reserator keeps my p4Ht 3.4 at 50 on load.
