Hi
Parts
Motherboard Asus P6T Deluxe v2 Intel X58 (Socket 1366) PCI-Express DDR3
Cpu Intel Core i7 920 D0 Stepping (SLBEJ) 2.66Ghz (Nehalem) (Socket
GPU XFX GeForce GTX 275 896MB GDDR3 PCI-Express Graphics Card
RAM Kingston HyperX 6GB (3x2GB) Intel XMP DDR3 12800C9 1600MHz
HD Western Digital Caviar Black 1TB SATA-II 32MB Cache - OEM
PSU Corsair TX 650W ATX SLi Compliant Power Supply
CPU Cooler Noctua NH-U12P SE1366 CPU Cooler (Socket LGA1366)
Case CM HAF 932
Would like to overclock to 4.00ghz. Do not want to change any voltage settings.
I can find out idle temp but not sure on load temp. I got speedfan.
Well speed fan reports cpu 30c idle but im not sure on load how do i find out.
What prefrences do i need to change in bios. (any precautions etc..)
All i need is figures and what to change, how much etc..
The idel temp for my gpu is 58c is that hot?
thanks for any help
Parts
Case CM HAF 932
thanks for any help
