Just created a Backup batch file but need some help?
28 Dec 2002
Northern Ireland
This is the Batch File i have created however i always keep some files on my desktop that i would like to backup using this bathc file.
I have inserted a line to backup the desktop but it doesnt copy any files or folders???
Im stumped can anyone help me out???
@Echo off
:: variables
set drive=J:\Media Centre Backup
set folder=%date:~7,2%
set backupcmd=xcopy /s /c /d /t /e /h /i /r /y /h
echo ### Backing up My Documents...
%backupcmd% "%USERPROFILE%\My Documents" "%drive%\My Documents"
echo ### Backing up Desktop...
%backupcmd% "%USERPROFILE%\Desktop" "%drive%\Desktop"
echo ### Backing up the Registry...
if not exist "%drive%\Registry" mkdir "%drive%\Registry"
if exist "%drive%\Registry\regbackup.reg" del "%drive%\Registry\regbackup.reg"
regedit /e "%drive%\Registry\regbackup.reg"
:: use below syntax to backup other directories...
:: %backupcmd% "...source directory..." "%drive%\...destination dir..."
echo Backup Complete!
@pause
2 seconds just checking the batch file again,...
Try running without @Echo off at the start so you can debug it.
I'd imagine copying a whole drive would be possible using the /E switch. i.e.
xcopy /E e:\ <destination>
This is great guys thanks going to try this out now
HangTime said:
Try running without @echo off at the start so you can debug it.
any other info on how i get it to run when i log off or shutdown
Create a shutdown .bat file which does the copying and then shutsdown the pc from the command line. So to backup and shutdown you would just double click an icon on the desktop.
cheer sthats great
however still cant get the file to backup my whole E drive.
New code:
@Echo off
echo ### Backing up Data Drive - May take several minutes...
xcopy /E e:\Data Drive
@exit
ace2109 said:
cheer sthats great
New code:
@echo off
@exit
Try this
Code:
xcopy /Q /Y /E /I e:\* c:\Backup E Drive
Still a no go mate, get the following coming up
****** Complete System Backup ******
### Backing up Data Drive...
Access denied
Unable to create directory - J:\Media Centre Backup\Data Drive\System Volume Inf
ormation
Invalid number of parameters
****** System Backup Complete! ******
Press any key to continue . . .
Looks like it's failing to copy over the System Volume Information dir, which you won't need. Try using the /s switch instead of /e maybe unless there are any empty dirs you really need to be copied over.
Still no luck coding now looks like this with the same error message:
@Echo off
echo ****** Complete System Backup ******
echo ### Backing up Data Drive...
%backupcmd% "E:" "%drive%\Data Drive"
xcopy /Q /Y /S /I e:\* c:\Backup E Drive
echo ****** System Backup Complete! ******
@pause
@echo off
@pause
Won't it have to be xcopy /Q /Y /S /I e:\* "J:\data drive" instead?
Sorted guys:
@Echo off
@pause
just had to delete this part of the code
and it worked fine
