Just finished a new build but not getting a display up now :( help!!
8 Jun 2006
Hertfordshire
Hi Guys
Just completed a new build, all went well but first boot and the monitor says no signal??
All cables are plugged in to graphics card, motherboard etc etc but nothing?
Any ideas chaps??
Spec below
Samsung SM2443BW 24" Widescreen LCD Monitor
XFX ATI Radeon HD 4870 1024MB GDDR5 TV-OutDual DVIHDMI (PCI-Express) + Company of Heroes Bundle - Retail
Asus M3A79-T Deluxe AMD 790FX (Socket AM2) PCI-Express DDR2 Motherboard
AMD Phenom II X3 Tri Core 720 Black Edition 2.8GHz (Socket AM3) - Retail
Corsair TX 650W ATX2.2 SLi Compliant Power Supply
Samsung SpinPoint F1 750GB SATA-II 32MB Cache - OEM (HD753LJ)
Antec 300 Three Hundred Ultimate Gaming Case - Black (No PSU)
OCZ DDR2 PC2-6400 Titanium 4GB Edition Dual Channel (OCZ2T800C44GK)
Razer DeathAdder Blue 1800dpi High Precision Gaming Mouse - Retail
Pioneer DVR-216DBK 20x DVD±RW SATA Dual Layer ReWriter (Black) - OEM
Try a CMOS reset sometimes works, double checked the 4 or 8 pin for cpu power is connected.
Remove memory bar one stick, if that fails try the other stick.
Right I have a dead stick of RAM, took second stick out and it booted with display and I got into BIOS, took the good stick out and put the bad one in slot one and no boot again!!
So I think thats it, will call OcUK first thing in the morning and get it sorted!!
Many thanks guys, hope thats the only hitch I have :(
I take it your on vista 64?
It might not be the ram, vista likes to be installed with only one stick in.
Install SP1, then put the RAM back in
