Just Formatted My PC - CPU Temperature Problems
Status
Not open for further replies.
1 May 2004
Hi,
I just formatted my PC, am running Asus A8V Deluxe Mobo with A64 3500+ CPU. No overclocking as yet, however my CPU temperature has jumped to around 80C with 100+ under stress, whereas it used to average around 40...
Settings are as:
Voltages:
+11.551V +12V
+4.999V +5V
+3.328V +3.3V
+1.712 +Vcore
CPU Temp: Approx. 80C
Mobo Temp: Approx . 23C
Fans:
CPU: 3200RPM
Power: 1700RPM
Chassis Fan: 2000RPM
I'm thinking that the CPU fan may be operating a bit slowly, is there any way I could speed it up. Otherwise the +12V voltage is looking a little low...
Any thoughts?
Thanks
Check the voltages and temps in the bios.
1.7V for the cpu voltage (vcore) is very high and could damage the cpu, I think it should be between 1.35-1.4V. Try resetting the bios to defaults or set the voltage manually.
Status
