just got a i5 2500k wow but.? how do i ?
30 Aug 2006
i have heard of this great video encoding etc i normally use convertx2dvd , but how do i enable it with the i5? i have lucid etc installed ? and a z68 mobo msi gen 3 ;)
As above Intel Quick Sync doesn't work with convertx2dvd - so your cpu is solely used to encode the files whether you have a Z68 board or not.
Best set-up for convertx2dvd:
under settings > Video processing
Multicore processor: Max number of used core(s): 4
under settings > Encoding
Conversion priority: Higher
this will give you optimum speed without crippling your whole system and you will still be able to have convertx2dvd running away in the background whilst browsing.:D
