Just got my belinea 22inch, some questions
Permabanned
26 Nov 2006
guildford, surrey
First off, all is set up and no dead pixels or anything, im current trying to set it up the correct colour and everything, but i have some questions,
What Does pixel clock mean in the settings?
What does Phase Mean?
For colour, should it be at 100 for red green and blue?
Also, when i hooked it up, i didnt bother using the stuff that came with the monitor, just used the vga, power and sound cables that were in my old one, seems ok but not sure if im ment to do that.
Also, anyone with this monitor, can you tell me what H and V position you have this at for 1680x1050? I cant seem to get the right one. EDIT: Autoadjust fixed that :p, but would still like to see settings that other people are using.
Cheers.
PS: Im only asking these questions as the manuel is pretty useless.
Cheers.
did you download the driver from berlinea website. so far i turned the brighness way down as it was dazzling and used auto adjust, colours etc seem ok and quite similar to the colours on my sammy.
