- 20 Jul 2009
- The bleak North East arm pit of Britain
*****JUST IN ***** . LaCie XtremKey All-Terrain Flash Drives. As seen on the Gadget Show!! Tested to the brink of destruction these XtremKey Flash Drives continue to carry on working. If keeping your data safe is a key priority or if your just a little clumbsy then there is nothing more secure. Check out the youtube video to see just how good these little drives are!
LaCie XtremKey All-Terrain 8GB USB 2.0 Flash Drive @ £39.99 inc VAT
The XtremKey is LaCie's strongest, toughest USB key yet. With an impenetrable shell, the LaCie XtremKey is a truly rugged USB key that stands up to the elements. The XtremKey is constructed with zamac, a metal alloy composed of zinc, aluminum, magnesium and copper that’s so strong, it can withstand the pressure of a 10-ton truck. The XtremKey’s memory modules are shielded inside of a 2mm casing and sealed with wear-resistant screw threads and a rubber O-ring, which makes it watertight up to 100 meters. In addition, it’s resistant to 5-meter drops, fierce heat and bitter cold—it holds up in any environment, no matter where you take it (+200°C / -50°). Equipped with the Hi-Speed USB 2.0 interface, the LaCie XtremKey offers instant compatibility, outstanding transfer speeds and cross-platform convenience to all PC and Mac users. With speeds up to 15MB/s (write) and 40MB/s (read), you don’t have to sacrifice performance for protection.
- Full metal casing - 2mm thickness
- Heat-, cold-, water-, pressure- and drop-resistant
- Outstanding write and read performance
- Wear-resistant braided metal cable ring
- Warranty: 2 Years
Only £39.99 inc VAT.
ORDER NOW
LaCie XtremKey All-Terrain 16GB USB 2.0 Flash Drive @ £62.99 inc VAT
The XtremKey is LaCie's strongest, toughest USB key yet. With an impenetrable shell, the LaCie XtremKey is a truly rugged USB key that stands up to the elements. The XtremKey is constructed with zamac, a metal alloy composed of zinc, aluminum, magnesium and copper that’s so strong, it can withstand the pressure of a 10-ton truck. The XtremKey’s memory modules are shielded inside of a 2mm casing and sealed with wear-resistant screw threads and a rubber O-ring, which makes it watertight up to 100 meters. In addition, it’s resistant to 5-meter drops, fierce heat and bitter cold—it holds up in any environment, no matter where you take it (+200°C / -50°). Equipped with the Hi-Speed USB 2.0 interface, the LaCie XtremKey offers instant compatibility, outstanding transfer speeds and cross-platform convenience to all PC and Mac users. With speeds up to 30MB/s (write) and 40MB/s (read), you don’t have to sacrifice performance for protection.
- Warranty: 2 Years
Only £62.99 inc VAT.
ORDER NOW
LaCie XtremKey All-Terrain 32GB USB 2.0 Flash Drive @ £102.99 inc VAT
- Warranty: 2 Years
Only £102.99 inc VAT.
PRE-ORDER NOW
- Warranty: 2 Years
ORDER NOW
- Warranty: 2 Years
ORDER NOW
- Warranty: 2 Years
PRE-ORDER NOW
