installed my xfx geoforce extreme 8800gtx which came yesterday.
had a problem with the length of the card,eigth of an inch to long,(quietpc case)lucky for me,there where some holes on the edge of the hdd cage,one was in line with the card,so i only had to hacksaw about one eigth in twice,then i had plenty of space to fit the card in.
the software installed okay.
the temps at idle are 60%C,72% playing wov(bob2).
i have the gpu fan in rivatuner running @70%,pretty silent.
does anyone think those temps are to high?
my 1900xt used to run at 45%C idle,60%load.
i was thinking of buying the arctic cooling "accelero xtreme",but not sure about it.
one problem i do have is,the monitor doesnt use the DVI-D,it uses the DVI-A,which i have tried to change on the monitor,but it wont have it.
my ATI 1900xt used the DVI-D,no problem,and im using the same cable.
is anyone else able to use the DVI-D with the 8800gtx on
an lcd monitor?
my monitor is a viewsonic VP2130b 22".
thanks.
an lcd monitor?
thanks.
) , kudos on the new card
Enjoy the new card and it's raw power
