- 24 Feb 2021
Hi Overclockers!
I've decided to join the forums as everytime I'm googling for info on housey things, I find interesting threads on here, even though it started as a computer related discussion forum.
So, we're in desperate need of taking back to brick or hall and landing in our 1920's semi because the textured plaster walls have confirmed white asbestos in them (Chrysotile).
We've had 3 quotes back but only one company has said they can remove the affected plaster and for the hall landing and along the stairs it will be £1400 to go back to brick.
We now also have a builder wanting us to decide dates to start the work so I'm feeling pressure. Because of lockdown we will need to put up or tent in the garden to be well clear of the fall out from the plaster removal (they are using a 'wet' removal method for the asbestos top layer) but I was thinking I should pay for an air quality test after too? I have a 5 year old in the house and just don't want to take chances.
Our quote, once back to brick is £5000inc VAT for dot and dab plasterboarding and skimming, panelling to 1m high with MDF and installing storage under the stairs. New skirting of needed is extra, as is a new for to the understairs. Bricks need removing to move the understairs for too.
So £6.4k for the lot but we will probably also be wise to get updated electrics put in and some additional sockets plus Ethernet while the brick is exposed.
Has anyone had their hall etc renovated and can share any issues they ran into, also what it cost in the end roughly and could advise on whether we should use insulated plasterboard on the external North facing wall up the stairs?
I'll miss a solid rendered plaster wall but I've been told it will add a lot to the cost and dot and dab is better but we do have the last bits of period features which this work will probably distrupt like cornicing and a picture rail plus decorative plaster ceiling.
It's pretty scary for me this stuff as it's a lot of money and I know the builder needs an exact brief, as do we, to be sure of cost.
I'm upload pics after work.
