- 30 May 2012
Hi all, Thanks for looking. Just planning on upgrading soon and wanting to know if things look alright to you all.
Asus P8Z77-V DELUXE Intel Z77 (Socket 1155) DDR3 Motherboard
Intel Core i5-3570K 3.40GHz (Ivybridge) Socket LGA1155 Processor (77W) - Retail
Crucial RealSSD M4 128GB 2.5" SATA 6Gb/s Solid State Hard Drive (CT128M4SSD2)
Corsair Hydro H100 Extreme Performance Liquid CPU Cooler (Socket LGA775/LGA1155/LGA1156/LGA1366/LGA2011/AM2/AM3) (CWCH100)
G.Skill RipJawsX 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (F3-12800CL9D-8GBXL )
I chose the more expensive Asus board for the vast amount of features and slots compared to the LX version. the SSD for hdd caching to speed up the SATA2's i currently have. I also chose the Hydro H100 for overkill cooling to ensure i dont end up frying the i5 when it comes to overclocking it.
My main concerns though are, is the asus board over the top? will the ssd caching be worth having, will the performance be "omfg" compared to the Q6600 2.4 quad core im using currently.
Thank you for reading and a thank you for any advice. If you think of a better build please do let me see it and explain why, i'll consider every answer.
