Just ordered a prodigy and bits but worried it may not fit.
12 Feb 2009
London
Ok so have a white prodigy with the following bits on the way.
Bitfenix recon white fan controller.
Bitfenix specter pro white with white led 230mm.
Corsair h100 with sp120 fans.
Bitfenix specter pro white with white led 140mm.
Now with the 230mm fan up front and the 140mm in the rear will the h100 fit with the recon?
Thanks in advance.
I've got a Prodigy, Along with a 230mm Spectre pro, Ek 240mm Rad in the top, 140mm fan at the back and a Recon up front and it all fits.
Cant guarantee it will fit in your example, Was just providing my 2p.
Edit: There is very little clearance at the front where the Rad and the fan controller meet, This is without fans. I have no chance of fitting a fan at the front.
At the moment yes, I'll be ordering another two though and mounting them outside the case at the top. Should knock a few degrees off the temp as it may as well be passive at the moment.
Well case came and up and running. Just waiting for the H100's to come off the boat and will swap out the current H50.
Mate can you snap a picture of what she looks like at night with the house lights off? Also what graphics card did you go for?
Cheers
Mawders
Looks great mate! Looking at those window pane doors, its a bit strange that they didn't integrate ventilation holes like the regular doors - especially because that's where the GPU is sucking in air from. Be interested to see what the effect is on temps...
Thanks. I finally got around to setting up the auto settings on the fan controller and im happy with it. Just normal use its nice and quiet then once a game starts up and temps rise so does the fans. Only problem is I will need to adjust them as it heads towards winter.
I've got a Recon as well in my Prodigy, it's such a perfect combo isn't it.
I've got my H60 Rad mounted at the rear, do you reckon it's best to mount it at the top of the case instead? I know this would allow me to Push/Pull?
