Just smashed my Xiaomi Mi Curve 34uw - need a replacement asap
29 Jan 2007
Hi all
Smashed my Xiaomi mi curve 34 uw today installing a new desk. I almost just grabbed a direct replacement but would like to know if there is better available from oc for £400 or under. I was thinking the Gigabyte 34" G34WQC-A?
Any other suggestions? I mainly play warzone and elden ring.
Has to be 1ms, 144hz and 3440x1440. I have a 3080 with Ryzen 7 3700x, 32gb ram
Thanks in advance
I'd consider the HP X34. Bang on budget with 165Hz IPS panel, unless you're set on sticking with a curved display.
The fact you think that VA panel is actually 1MS means the monitor marketing bs is doing it's job at least then ....but yea the HP X34 is a good option and will be quite a bit faster in real terms being IPS so have better motion handling, the Iiyama GB3461WQSU-B1 is another flat IPS option and very similar, if you do want another VA then the AOC CU34G2X or Samsung Odyssey G5 are fair bets.
