Just some advice on cpu temp
23 Jan 2017
Hi, so i have just built a new PC and last night it got to 70c in the bios which was very worrying, so i applied fresh thermal paste and rotated my cpu fan and now i am getting 30c idle.
My question is, is 72c max temp fine for playing an unoptimised game at ultra settings? my cpu is round the 63c mark most of the time but it does occasionally creep upto 72ish, should i be worried or are them temps fine?
I am using an i5-7600k, msi geforce gtx 1070 and a cooler master evo tx3 cpu cooler.
Are those stock/non-overclocked temps?
Which motherboard is it?
What's the Vcore reading in the BIOS and what LLC (Load Line Calibration) level is it set to?
http://www.techradar.com/reviews/pc...ng/cooler-master-hyper-tx3-evo-1041958/review
Edit got
Noctua NH-U14S & Noctua NH-U12S
will fit the Noctua NH-U14S and test.
It's at non overclocked temps, the mobo is an asus prime Z270-p and i am not sure on the vcore reading in the bios or the llc level. What should it be set to?
Alright, you can try downloading (if you don't have it already) CPU-Z and looking at the max Core Voltage reading there when you stress the CPU. You could stress with something like Cinebench, which doesn't take long.
Your temps are fine if you want lower temps then buy a better cooler and make sure your case is getting plenty of fresh air in and hot air out.
He shouldn't need to buy a better cooler if he's running at stock.
Plenty of Asus motherboard owners (there's plenty of posts about it on this forum alone) who run their CPUs at stock, were able to lower temps by anything between 10-20 degrees, by reducing excessive stock Vcore and LLC. It would therefore be interesting to see Vcore reading, and take it from there.
I'm not saying he does but if he wants lower temps then a better cooler will do that also plus give him head room should he feel the need to squeeze more out of his chip.
Better cooler = lower temps should be pretty obvious to anyone who's taking note of temps and can manage to apply fresh thermal paste and re-mount the cooler.
Two things -
Saying that the temps are fine when he's only mentioned it gets up to 72C in a game (without stating whether CPU usage was at 100% or not), is not good advice. How do you know those temps may not get higher, if it was the case that the game was not even using 100% CPU? Better to make sure that's the max temp (Prime and a few other tests excepted) before saying temps are fine.
What I've suggested can provide the option to possibly lower temps for free, if he wants to continue at stock. As it's quite a common thing with recent Asus boards/BIOSes (Z87 up).
