Just swapped my Scythe Ninja for a MINE
3 May 2004
UK
The ninja was to big for me to mount my fan near the memory slots and near the nothbridge. I decided to buy the Scythe MINE and have positioned it so the comes out of my Silverstone TJ07 via the two 120mm air vents at the top. I have turned those 120mm fans off.
I have kept the rear 92mm fans on at 5V and my temps are 23deg C idle, with a 92mm fan at 1000rpm inside the MINE. The ninja was getting 26deg C with the two 120mm fans on the top on, and it was fairly audiable. My current configuration is much quieter.
Load temps I get around 33deg C. With the ninja it I got 46 deg C. I think the MINE is a great purchase but I cannot install a 120mm fan beacuse I can't get the side panel back on. I have therefore installed a YS Tech 92mm fan.
Also the LGA775 mounting is brilliant. I don't need to remove my motherboard from my case like the ninja.
PRO's
Mounting
Temps
Small size comapred to ninja
Quieter than ninja while achieving low temps
CON'S
Cannot install 120mm fan
I cannot wait for the Conroe. I can then run the fan at 600rpm and make it almost silent.
but if the same sensor gave him a higher reading with the other fan, then its still an improvement... but er yeah, you will find most temp reading sensors on the motherboards are often wrong...
Yeah I know but kchakkar wrote that reply like there was a difference between uguru and bios readings. There's only one sensor on the motherboard isn't there? unless uguru has its own, I thought it was just software.
