Just testing the water...
15 Jan 2011
Midlands!
Excuse the pun :o :D
Thinking of watercooling my PC, CPU and possibly GFX as well.
But im not too sure how well a watercooling kit will fit in my case.
HAF922. All other hardware in my Sig.
I know ill need at least a double rad for my SB chip @4.4. But will adding a single rad as well accommodate the 480?
Thanks! Sorry if this thread hasn't made too much sense, written it quite sporadically.
Will a 240 and both fans fit on the inside of the case? and also will the 120 and accompanying fan fit on the inside of the case?
Also thanks for the quick reply!!
ye its a good kit and will do the job fine. but if you get another 120 rad and fan you will be able to have the fans on really low or not at all and still have good temps and silent computer.
it will cost you about 30-40 for a rad and then 3-15 for a fan and 2 barbs thats all you need. ask them how long the tubing is they might through you a tiny bit more in
Epic :D This is on the list for after Christmas then, once I know how much spare cash ill have.
Might give a couple of calls to OCUK HQ as well closer to the time just to clarify sizes of rads etcetc.
Don't want to **** this up :D
Im feeling like putting together my own loop instead of buying a bundle one.
Might make me learn a bit more too!
EK look awesome!
Edit because i used the dreaded F
T
W
so many conflicting opinions?!?!
Also
Hows this for a shopping basket?
edit: photo was a bit small
Hey mate,
Looks alright to me but I'm no WC expert. Don't waste £1.30 on that bridging connector when you can do it yourself with a piece of wire though.
Edit : No watercooling pump?!
EK res combo is with pump is it not?
yes, also, try using the ocuk shopping basket app for chrome, makes speccing easy :)
EDIT:
better (but more expensive) basket:
YOUR BASKET
1 x EK FC580 GTX+ Full Cover Waterblock - Nickel Plexi **EN Nickel Plating** £79.99
1 x OcUK Tech Lab - 10w DDC Pump & Alphacool Acetal Top Value Combo £65.98
1 x XSPC RayStorm CPU WaterBlock (Intel) £49.98
1 x XSPC EX240 120mm Radiator - Black £39.98
1 x Phobya G-Changer 120 Ver. 1.2 Black £33.98
1 x Alphacool Cape Corp Coolplex Pro 10 LT £16.99
1 x Masterkleer Hose Pack PVC 15,9/11mm (7/16ID) Clear 3.3m £10.88
1 x OcUK Tube Cutter Aluminum 3-14mm £8.50
12 x EK PSC Compression Fitting 7/16 [16/12mm] - G1/4 - Black £3.50 (£42.00)
Total : £360.34 (includes shipping : £10.00).
