- 8 Jan 2006
- Leicestershire
Spec in sig.
I've got my system installed and running OK (not loaded an OS yet though). Problem is I could find no way of connecting power leads to each of the GTXs - there's simply no way the plugs can fit because of the hard drives. It occured to me that maybe I could just use the ASUS EZ Plug, which is what I'm using now - is that correct or am I going to have to find another way?
Like I said, not running Windows yet. Cheers!
Can you buy these cables from OcUK?
