Justcompatibility for these components
looks like cooler wont fit
case - Max. CPU cooler height: 105mm
cooler has 120mm fan, so its 159 mm high
possible solution
My basket at Overclockers UK:
Total: £225.48
(includes shipping: £10.50)
Would this cooler work https://www.overclockers.co.uk/cooler-master-masterliquid-lite-120-aio-cpu-cooler-hs-07j-cm.html
I would get a better psu than the CX series, fully modular would be a big advantage in such a small case as well. The Seasonic Focus Plus 550w is a much better psu than the CX series. It's gold rated, fully modular, has a 10 year warranty and at a compact 140mm long will still fit the case. It also has a hybrid fan mode which means when turned on, the fan doesn't spin until the psu hits a certain temp or load. For a extra £16 it's well worth it to get a very high quality psu. You can read a review of it here at Jonnyguru.
