JVM not found? (Pse Pro)
2 Nov 2002
Aberdeen
I currently have installed
Windows Xp Media Center
Jdk 1.5.0
Jre 1.5.0
Whenever i try to install Pse Pro trial, the installer pauses on 8% downloaded, and then declares that the Java Virtual Machine cannot be found.
I've done a search and all i can find it to 'set the JAVA_HOME environment variable to the installation location of the jdk. For example, if the jdk is located at /usr/java142, set JAVA_HOME to /usr/java142 before running the command to install the product.'
However, i have no idea how to do this, or where to do this.
Any help on this matter would be much appreciated
