K2 mount doom question
17 Apr 2012
Hi All
Just a quick question. Now that I think of it, my cooler above is quite loud. Would the fans be running full pelt all the time if only plugged into a 3 pin on mobo when the fans themselves are 4 pin?
Thanks
Yes they'll be running at full whack, a 3 pin fan is negative, positive and tacho, but with 4 pin you get extra wire for PWM (pulse width modulation)
Also your mobo has a 4 pin connection just by ram stick above cpu slot
Thanks
Im using the 4 pin, and then have the 2nd fan plugged into a 3pin. Perhaps I have to adjust something in bios settings
On the k2, both fans can be ran via the single 4 pin PWM connector. The 120mm fan has a connector branching off on it's cable. You could connect the 140mm fan to this. This would allow control of both via the cpu fan header. Another method is to use a PWM splitter cable like this.
http://www.overclockers.co.uk/showproduct.php?prodid=CB-031-AK&groupid=1929&catid=153
This cable is powered by a molex connector, therefore no load is placed on the cpu header. Some board manufacturers are now installing dual 4 pin cpu fan headers on their boards, this is down to the rise in popularity of dual fan coolers. My board in sig has dual headers therefore my k2 fans have their own fan header.
Haha cheers!
I saw that before and just thought, what the hell is that?. Ive connected that now. But still seem to be running at max. Do I have to enable any features in mobo bios?
Yep, there will be fan control options in bios, or with software bundled with your board. Not sure what theyre known as on an msi board.
It's a little on the high side, but nowt to worry about. Temps will depend on factors such as case airflow, ambient room temp etc. Load up coretemp and let it run in the background while playing games. It will show current temps, and minimum, max temps along with cpu load. To check at 100% cpu load, you'd need to run a stress program such as prime 95 or intel burn test. Theese will generate much higher temps than games.
Mike, is your 4.5OC on constant or do you have speedstep enabled?
It's just that I have speedstep enabled and even with the K2 fans switched off, my idle temps don't go above 27c or so.
Room temp is around 20c and our cases are internally the same fwiw.
Its on constant as far as I know. It was a bundle from Overclockers a while back. Though I have changed parts since then, I haven't messed with the OC profile,though I might start to. I could look at reducing the V-core which is 1.376 to see if that could lower temps.
Ok, in that case it's probably about right.
Fwiw, my vcore is about 1.376 too, but my OC is just a simple multiplier change on auto voltage.
Unless your chip runs differently to mine, it sounds like they were as lazy with the OC as I was :D
Saying that, I looked at the bios last night and speed step was enabled. But even after I set Vcore to auto, it didn't drop down when idle. Am I missing something?
Is your Windows setup set to High Performance under power options?
Stolen from google to show my point.
Change the min state to 5% and hopefully it will start stepping.
i think C1E has to be enabled, dont think you need auto on vcore though.
it will keep temps lower when your not using/stressing the PC also using less power. purely personal choice i feel. lost say its more stable to have it contstantly at OC value, i personally haven't noticed any issues when using it.
I enabled C1E, while it did drop on idle, it was also erractic jumping 1.6 to 3/4/2/4ghz etc. So for now Ive disabled it and just put smart fan target on so fans are quiet while doing nothing.
