k62 swap to a 800d watercooling.
28 Oct 2010
Colchester
Hi guy's and girls.
I dont know if you remember a few months a i did a project on watercooling my lancool K62 case, if not click here .
Well i really enjoyed doing but after few months i wanted to watercool my 6950/70 as well so i did but i found the temps where a little hot so i
brought another rad but where the K62 case ain't that big i could not fit it in so I change the case to a 800d, i brought it from schizo (thank m8ty).
Well 2day i got round to moving my kit from the k62 to the 800d.
Here are a few picture, not a lot sorry i got carried away setting it up :D
here what it look like before:
and here is what i did 2day.
2morrow i need to sort out the cables as they are a mess at the mo, so after i will post some more pictures and post some temps as well.
At the mo my cpu is running 25'c idle and 40'c fully load @4ghz on prime 95.
My 6950 flashed at 6970 is running 25'c idle and 35'c fully loaded.
hope u like the few little pictuer i have posted.
Looks good! Did you cut a section at the bottom for the 240 rad to ventilate? Also, did you replace that mesh schizo put on with acrylic?
Cheers
burrell,
Sorry that was a typo it ment to say 35'c load, sorry.
Thanks you :).
Guitarman0,
Yes I did cut the bottom for that rad :D.
Yes I found a place what cuts out acrylic it only cost £15 incl p&p.
My loop goes, 360 rad - CPU - res/pump - ek 240 rad - gpu - 360 rad.
burrell,
Thanks you :).
Guitarman0,
Was cutting the holes for the 240 difficult? Also, were the rivets hard to remove? I am getting an 800D soon and I currently have a 280 rad in my K62 which I am very tempted to put in the bottom of the 800D along with a 360 at the top :)
it took me about 15mins if that to remove the cage out, with the rivets all i did was got a flat headed screw driver and small hammer and tapped them out.
There is enough room for a 280 rad.
I will be posting more picture up later, just got in from work, so give me a little bit then i will.
All of these watercooled 800D build logs is giving me a rather expensive itch to try one. they all look so good :P
800D is just awesome to work with ... very forgiving if you have an accident or two as well :D
UPDATE: More pictures due to that i have swap my hardware around now back in may but forgot to update the log, lol.
Spec:
i5 2500k @ 4.7ghz @ 1.36v
z68-ud3p-b3 mobo
gtx 580 3gb @ stock
Pictures:
scaled.php
scaled.php
scaled.php
scaled.php
scaled.php
scaled.php
scaled.php
scaled.php
Just out of interest Sgt Tackleberry ,
are the fans on the bottom rad pulling air in or out ?
The fans are blowing in on the bottom rad. I have now changed all my fans to the viper's, temps haven't moved but its really quite now.
Am liking the look of that Sgt Tackleberry, nice n clean looking not overcrowded bright yup am liking that a lot :)
Thank you very much :).
Muchy likey but which way the tuck is da fans blowing :D
Are you on about the bottom rad still or the top rad?, Top rad i have 6 vipers fans on a push pull config now.
Bottom rad i still have 2 fans on it and blowing in.
Very sad news this morning my pump died on me so i've got to get a new one now, going to looking on the MM in a min.
Well ive already got a triple in the top but im adding the double in the bottom and also debating whether to put a single i have spare at the back maybe,
although ive just measured it and looks like its going to be very close to the mosfet block.
