K70 RGB help
28 Dec 2003
Ok so I've just hooked up a K70 RGB and I'm already confused as hell.
The keyboard appears to have three built-in profiles. A spiral, a left-right sweep and a kind of rain-drop type thing. I can cycle through these using the profile key and decided I quite like the left-right sweep.
Then I installed iCue and all has gone strange. This only has the spiral pattern listed and this is all that's available - the feature key no longer does anything.
When the computer is locked however, it seems the keyboard reverts back to its original settings and I can cycle through the profiles using the key and select my left-right sweep again. As soon as I logon again though, the iCue software takes over and I'm back to the spiral.
What gives? How do I get the left-right sweep to stay or do I have to load it into the software somehow?
I'd read that Corsair's software was unintuitive but I had no idea it was this hopeless.
Any help appreciated as trying to Google Corsair/CUE throws up a gazillion results.
Make sure the profile you want active is at the top of the list (mouse click and drag) as this is the active profile.
Best
Wulf
