K750i Noob
25 Jun 2003
Scotland
Just got this phone today, its unbranded and ive put in a vodafone simcard the question is i cant connect to the internet with it, ive downloaded various WAP settings from vodafone and Sony Ericsson and still cant work it out. What do i need to do? Cheers
Should just install once you receive them, i did mine earlier today but i have the w810i but its more or less the same thing. All i did was press yes when it asked me to. 1 min later i was browsing the net on the phone and d/l'ing emails via gmail.
Try it again unless its a differnt method to get the net working on your phone.
i'm guessing if it's unbranded you didnt get it from voda. this might help you.
when i upgraded FROM a K750i with O2, my GPRS features didnt work anymore. i assume this is because, according to them, i should be using a W810i with a different IMEI number. i'd give Voda a call and tell them you've got a new phone; you're having trouble accessing WAP, even though you've got all your settings.
also, check your profiles, you might have more than one GPRS/Mobile Web/MMS profile on there, which it's trying to access instead of the ones you're installing.
hope any of that helps :)
I phoned vodafone and they had to put the internet services on for my account, all working now.
Cheers Anyway.
