K800i firmware update HELP where do i download it from
It solves bug fixes, not a lot new really just feels rock solid when doing things. I advise you to upgrade the firmware because its free and fixes known problems.
Anyone got this working on x64 vista?
When I open the update software, vista is asking to install SEMC USB Flash, and it can't find it online or on the disc that came with the phone.
I dont think its working with Vista yet, though I have not checked recently. I updated my phone a short while ago and the only difference is you get a thumbnail of your vids which play if you have them selected. Still a great phone though, cant wait to get my K850i
Works fine with Vista although it doesn't seem to list the K800i on the website. As soon as you load the software it works fine.
I never had any real issues with the K800i anyway but decided to update the firmware. I'm not sure if it's my imagination but it seems a little quicker than before but the only thing I don't like is you have to press the star button only to unlock the keys. Beforehand you could press any key and then followed by star.
I keep getting incompatible micromedia version when I try open it. Even though I'm using the latest one out there :S. (This is for the k810i btw, doesnt really matter though)
