K8N Neo4(MSI) problem
13 Sep 2005
Crewe,Cheshire
MSI Mobo problem
Same post as in mobo section, as i've not had a reply yet and im still having trouble
Im having some problems with a pc fitted with a K8n Neo 4 it had decided too stop firing up at all so i removed everything from the mobo except the cpu and fans and it fires up sometimes it seems very hit and miss but i have not managed too get a picture out of it at all yet.
When it does decide too actually do anything at all it is showing some lights on the D-bracket2 (the bracket with four integrated diagnostic LED's on the back of the case), which are top left GREEN, top right RED, bottom left RED and then no colour at all on the bottom right LED.
I should say the board will fire up the same with everything but the Graphics card fitted. But its still only as and when it seems like it wants too, wont actually do anything 85% of the time. Also i have checked and its not the case switch.
any ideas ?
Do you know what that ligth combo means?
It could be your power supply or the actual mobo itself. seems to me that if it was anything else the board would still power up just wouldnt go through the post
