I owned a corsair K90 Mechanical Keyboard for 8 months now and I have decided its time to clean it up. As usual I removed all the keys from the keyboard and cleaned it.
Problem: When placing the keys back together i noticed for each time i hit my spacebar it sinks to the keyboard, it doesn't go up. So i'm left out with a broken spacebar. I'm guessing is the "spring" inside the keyboard? You recommend i should open it up? Thanks.
