So I recently just bought the Corsair RGB K95 Platinum but Im finding it a little confusing on how exactly are you supposed to customise the colours with different profiles but then for example save it as a hardware profile, or at the very least remember my last selected profile when I start Windows.
I have downloaded several profiles from the CUE software which I can select and see the new colours and effects but when starting Windows it always selects my first downloaded profile, not my last used. I dont even see a way of overwriting one of the 3 hardware profiles with one of the custom or downloaded ones?
Does anyone with any experience using the software or keyboard have any ideas? I just want to know how to save to hardware profile and also how to remember last selected profile.
EDIT: I forgot to add whenever I open the CUE software I always get this annoying error saying the profiles conflict, "The stored profile K95P HW1 on your device does not match the current profile saved to CUE." This message appears 3 times for HW1, HW2 and HW3.
Thanks
Thanks
