There's a fair bit of noise going on in Case Central about Thermaltakes Kandalf LCS case and integrated W/C system.
Since I often posted in here and trust the comments coming from various user's I wanted your speculation over the possible performance of the W/C side of the case.
Currently, my PentD [email protected] runs at around:
CPU: 45 Idle, can hit 70C at full load (dual Prime full load, that is). Load in games/photoshop will make it hit between 58-64C.
System: 38-42C Idle, will hit 49C when the system is under a lot of strain.
This is with the pants Big Water SE kit that I have thats straining to keep the CPU tamed. Now add to that a toasty 580Watt PSU, a pair of X1900GT in Crossfire and you can see that I have a portable oven on my hands
Now, the LCS system in the Kandalf seems a bit of a gift horse considering the decent case it comes in.
120.3 Rad with 1300RPM, 17DB Fans
500 Ltr/Hr Pump
3/8" Tubing
350CC Res
Improved CPU block
Im a little wary of the CPU block, as the one that comes with the Bigwater SE isn't that great - you can see through the plexitop and it appears to just be a simple channel through the block, which doesn't seem to be the greatest design.
Anyways, this setup differs from what I have in the following from what I can see: tubing size increased from 1/4" to 3/8", Rad increased from 120.1 to 120.3, pump power increased from 90L/hr
to 500 L/hr....
Can this tame my PenD ?!
500 Ltr/Hr Pump
3/8" Tubing
350CC Res
Improved CPU block
to 500 L/hr....Can this tame my PenD ?!
