Karcher K4 screeching when you turn it on
6 May 2020
Hi just got a karcher K4 pressure washer and needed new pump changed pump now makes a screeching noise when you turn it on any help much appreciated
If I have understood your post correctly, you have got or purchased a (used?) Karcher K4 pressure washer, you've had to replace the pump and now it makes a screeching noise when switched on?
I gather you've connected the pump correctly and have turned on the water supply? If so, have you considered that it could be the pump at fault or something else?
