Don
- 20 Oct 2002
- Oxfordshire / Bucks
what's the actual action/movement of rowing like? the youtube vids of the game i've seen all use a a paddle accessory to mount the touch controllers, just wondering if it's decent without them?Just tried this and must say it looks amazing. The graphics are some of the best ive ever seen.
Play's fine over airlink, every setting on epic and DLSS also activated. Smooth as butter on my 2070 super.
The physics of the game are superb, the motion of the water is beautiful. Ive never been in a kayak before but it feels real.
I attached my controllers to a barbell and it worked great. Decent workout for the shoulders too. Might try also adding some light weights, seems like a fun way to exercise.
I wouldn't do that if I was you. Weights and VR don't mix. You have no control in VR, you will be overextending all the time because of the unpredictable movement in VR. The best thing that could happen is that you pull a muscle or something nearly straight away and that forces you to stop using them. But, what's most likely to happen is that you feel nothing. Doesn't sound too bad does it? However, it's actually the worst kind of injury. Because what the weights are doing is causing imbalances and strains on nearly everything in the body. These strains and imbalances build up over time until eventually you get nagging pains and aches that don't go away. Especially in the back, shoulders and wrists.
It's not worth it. The risks far outweigh any gains.
I'm just talking about little 1.25kg weights on either side, nothing heavy. I'd just be doing the standard simple paddling motion, can't see much danger of overextending.
There is a workout that uses the paddling motion like you would on a Kayak using a Barbell. However, like all weight bearing exercises, it's done with a controlled pattern of movement with the core engaged at all times. When you are playing a game in VR you won't be using controlled movements, you won't be able to see what you are actually doing and highly unlikely that you will be engaging your core either. I would bet money that, even with the Barbel only, when you are playing the game in VR you are hyper extending because of poor form.
And when you add extra weight on top of that you are only compounding the problem. Yes, even 1.5KG is, and if you are using a 7ft bar, it becomes a lot.
I would strongly suggest that you don't use the barbell or maybe an EZ Curl bar because it's short. Shorter means less risk.
