keep a motion sensitive light permanantly on?
27 Oct 2002
London
Without attaching a hamster to it...
Isn't there a certain amount of time u must flick the switch on and off and then the secuirty motion sensitive light will stay on?
Yes, usually off then on then off then on should do it, i'm sure it depends on the brand though...
with ours we have to switch it off twice then turn it back on within 3 (or might be 5) seconds and it will stay on until you switch it off (or put it back into the normal motion sensing mode
