- 10 Sep 2008
- Macclesfield, U.K.
hi, does any one know whats going on?
When i tell crysis to auto config the spec it put all to high or gamer mode.
I have a 4850 512 xXx graphics card, 6Gb of ram, amd quad 2.6.
Im running at 1080 res, wide screen.
Basicly on crysis i can get all the way up to where u have jusr disabled the com jammer at the start and it always crashes and it always goes to light and medium grey lines running verticaly.
On war head it runs fine untill i get to the crater at the start and then it does a bit of audo looping and crashes to black.
Both times i have to manual reset.
Am i running it to high?
Is my system not good enough
Thanks for any help.
(is it possible that i might need a 2nd card to cross fire? i would only do this if its 100% that this is the problem as all my other games run fine on full specs at 1080)
?Thanks for any help.
