Hello,
As per title, does anyone know why this could happen, I lose my connection for a couple of seconds completely randomly about 5-10 times per day, but it only happens sometimes!
I would have normal internet, then all the sudden I'd get a page not found error or so, I check my LAN icon on my taskbar and it's with a red cross: LAN cable not connected. And within 10 seconds usually it's back as if nothing happened ( without getting a new IP, ''identifying'', or any user action), like it was never gone! This has happened to me while online gaming too and results in a lag spike then back as usual.
None of the other devices ( LAN or WLAN) seem to suffer this problem. It happens on all ports on my router.
Like, I have had this problem before, then it was gone for a month or two, then it is back again. Rebooting the router fixes it temporarily for about 12 hours ?
What do you think, faulty router or fauly lan port (on my mainboard) or some kind of software error ?
My lan setup:
What is odd is that my PC shows an orange LED while the (port that goes to the) switch shows a green LED, anyone knows what it matters ? Sometimes my PC is Green instead of Orange:
Should I ask my isp for a new router? The odd thing is that the disconnects sometimes plague me for like a week, then its all OK for like months then it's back again...
My lan setup:
