keep or remove ?
30 Sep 2008
surrey
I saw the honda racing panels in the honda shop a while ago ,but at £40 for a couple af bits of vinyl i decided against :eek:. But picked a set up on fleebay for £15 and fitted this morning to go with the rim tape..
What you recon . Keep or remove . I cant make my mind up
Personally ide keep them, it breaks the paintwork up a bit, as i'm just not a fan of single colour, "minimal" paint/sticker schemes as theres a helluva fine line between "minimal" & bland.
I paid £40 for the Motograffix number boards for mine (similar to the ones you have) and then removed them pretty much straight away.. didn't like them at all, I thought I would.
P.S. Would you like some tyre with your portion of chicken? :D
