Hi there
Well overdue at OcUK, but now available we have Kensington locks, so if you enjoy going to LANS, keep your equipment secure with a Kensington Lock:-
Kensington Desktop PC & Peripherals Lock Kit @ £25.99 inc VAT
With a long high-carbon steel cable, anchor plate, and a Kensington keyed lock, the Kensington Desktop and Peripherals Locking Kit has everything you need to secure a desktop computer, two peripherals and a wired keyboard and mouse. Even devices without a Kensington Security Slot can be secured.
Features:-
- Hidden Pin™ technology ensures tubular locks cannot be picked offering the highest level of security
- Anchor plate secures equipment without a Kensington Security Slot
- Everything you need to secure a desktop computer, two peripherals and a wired keyboard and mouse
- Cable trap secures a wired keyboard and mouse
- Multi-stranded 2400mm long, 5.3mm thick high-carbon aircraft-grade steel cable with carbon tempered steel core
- 3M VHB industrial adhesive tape on stick on anchor for non-Kensington Security Slot equipped peripherals - 1 square inch (645mm x 645mm)
- Two keys supplied
- Custom keyed options available ideal for offices, labs and libraries
- Online key code Register & Retrieve™ and replacement service
- Supplied with stamped steel and plated K-slot adapters (2) and cable trap (1)
Only £25.99 inc VAT.
ORDER NOW
Kensington MicroSaver® Laptop Lock - Keyed Different @ £43.99 inc VAT
The MicroSaver® lock head features the patented T-bar locking mechanism. The T-bar provides a tight fit with the Kensington Security Slot. A rubber bumper ensures a snug fit between the lock and the security slot and protects your hardware. A further deterrent is the tamper evident feature. When a Kensington MicroSaver® lock is tampered with, it locks itself down and can even trap foreign keys.
All Kensington locks are built to exacting engineering standards. This lock is rated as Safe Pro, a rating awarded to Kensington Security Locks that are tested under stringent test conditions by third party testing agencies for their ability to withstand attacks.
We provide two keys with each standard lock. Each key is stamped with a unique code. Register your code online and we’ll be able to send you a replacement key.
Our business is protecting yours
Kensington locks are made with high-carbon steel cables and tested under rigorous real-world conditions to resist lock-picking, corrosion, tampering and extreme environments. Our locks set the industry standards, and continue to exceed them.
Features:-
- Tamper Evident™ technology alerts you that someone has tried to steal your device
- Anti-Shear™ technology protects against intrusion by force
- Multi-stranded 1800mm long, 5.3mm thick high-carbon aircraft-grade steel cable with carbon tempered steel core
- Built-in defense system guards against lock tampering
- Two keys supplied
Only £43.99 inc VAT.
ORDER NOW
Features:-
- Two keys supplied
ORDER NOW
Features:-
- Two keys supplied
ORDER NOW
