Mistakingly included this in someone elses thread. So starting afesh.
Quick spec:-
E5200 2.2 50GHz (800FSB)
Asus P5K EPU Intel P35 PCI-E DDR2
Antec Sonata III Piano
and other parafinalia LOL 2 case fans and a HDD caddy in a 5 1/2 bay with fan inside. Silence could be golden.
Important bit ~ 2x ati Radeon 4850 512 MB GDDR3 TV-Out/Dual DVI/HDMI.Graphics cards. Configured in crossfire. Didn't like the temps with the stock glaziers as one card heats the other in the PCIE slots(hot air rises). So beautiful sculptured an engineered "Accelero Twin Turbo" Good price juggled around like another chap on another thread (experience with removing procesors, I knew adhesion would be strong) The socket and plug on the board and the stock fan is smaller than my knew set up. Got round that by using a Zalman simple fan controller and the headers on the mobo. Would be more proffesional to use the card control and "Asus Smart Doctor." Oh and the wires use a different colour code. Can't assume pin for pin with £220 + worth of cards. Thanks if any one has ideas ~ I emailed Artic but no reply forthcomming. Scoured the manufacturers involved to no avail. For info addicted to flight sims FSX and a freebie Flightgear.org < thats a big challenge using 64 bit Vista. Cosidering returning 32 two simultaneous operating systems a bit ambition for a 59 year old rookie LOL
P.S. I don't want fixed speed connections to molex feeds I like silence when not loaded...... the graphics cards that is.
Quick spec:-
And a monitor at 1680x1050 resolution or above, as below the gains are very small.
