Hi all, im more of a PC builder, dont know much on laptops.
Basically my brother has been playing an online game on the laptop for weeks, no issues (a bit laggy but thats just the crap spec)
I decided to reformat the laptop a few days ago, since i did this the laptop keeps resetting while he is on his game.
I've been trying to find the cause, and basically the laptop is resetting when coretemp shows 95degrees. It seems some "auto" shut down at this temp thats causing it.
Now, i dont know if that temp is too high, or normal for a laptop, could anyone shed some light ? Also, the laptop has been fine before the format
He could play with no crashes for well over 7hours, now he can get 1hour max, sometimes its just 10minutes
The only thing i changed was the BIOS, i've tried about 7 different versions now and they all turn the laptop off at 95. The BIOS's seem very limited, i cant see anything regarding temps and shut downs like you can on a PC.
Anyone got any ideas?
Thanks,
Adam
(Laptop)
ACER Aspire 5100
AMD Turion 64 X2 1.6Ghz
1gig ddr2 ram
ati 1100 128mb grfx card
Thanks,
Adam
(Laptop)
ACER Aspire 5100
1gig ddr2 ram
