Kef 5005.2 Vs Kef 3005 speakers
Caporegime
27 Nov 2005
Guernsey
Would it be worth paying the extra for the 5005.2 over the kef 3005 speakers..
Looks like they both use the same new Kef subwoofer..
http://www.kef.com/ht3000/gallery.htm
http://www.kef.com/KHT/KHT5005/gallery.htm
But the specs of the 3005 speakers look better..
Everything in the specs just looks like the 3005 should sounds better....
(Frequency range is better on the 3005..3in vs 4.5in drive units,internal volume bigger on the 3005,maximum output & Sensitivity higher on the 3005..)
I prefer the looks as well of the 5005.2,,But the eggs would give me better mounting options (I know i be able to mount the eggs so they are all aiming toward me..(i think))
HTC3001 Centre Speaker
Frequency Range 65Hz - 55kHz
Drive Unit Array 115mm (4.5in.) Uni-Q
19mm (0.75in.) aluminium HF
2 x 75mm (3in.) LF
Internal Volume 2.4 litres
Maximum Output 110dB SPL @ 1m
Sensitivity (2.83V/1m) 90dB
HTS3001 Satellite
Frequency Range 70Hz - 55kHz
Internal Volume 1.75 litres
Maximum Output 108dB SPL @ 1m
Sensitivity (2.83V/1m) 88dB
HTS/HTC5001.2 Satellite & centre
Drive units
75mm (3in.) Uni-Q array with
15mm (0.6in.) HF
2 x 75mm (3in.) LF
Frequency range (± 3dB) 95Hz - 30kHz
Internal volume 1.4 litres
Maximum output (SPL @ 1m) 106dB
Sensitivity (2.83V/1m) 87dB
There no retailers where i can demo both these two sets of speakers where i live...
Have anyone here demo these two sets of speakers ????????
And would i really notice a lot of improvement with a set of these speakers & AV receiver compared to my logitech z5500 setup i be using...
The room they be used in is about 12ft x 9ft..
