I have a Spyder 2 calibrater as I use photoshop 5 a heck of a lot. Therefore it is easier to have a monitor that has a Kelvin setting than one with rgb, so I can easily set the gamma to 2.2 with the spyder. Takes ages using rgb.
My monitor at moment is the 24" DGM bought on OC when it first came out.
In photoshop when open, it now shows a bit of burn in, but you can't see it on desktop.
Also this morning the monitor started up and started flickering/flashing with some horizontal/vertical colour bars. Did this until it reached the startup screen. Win7 is the OS.
First time this has happened.
This is why I be looking for a Good monitor with 5 or 2ms that's GOOD for photoshop and other things. My 22" Samsung which is older is still going strong.
Also buying the Components for New PC shortly.
Thanks
P.S--
Hi PorkyPieCat
Clicked your link and read it all. Great reading. Thank You.
A pity the U2410 is expensive, there again though, the dell U2412M is pretty good according to that reveiw. In fact, the Black point is far better on this one (U2410M) even though it's only 95% gammut,than on the more expensive one. Don't make sense that seeing as the expensive one is for photographers. Also the U2410M has a 16:10 screen just like my DGM has, which is far, far Better for photography than a 16:9.
So looks like I shall buy the Dell U2410M. Unless of course you or others know of a better 16:10 monitor that's Good for photography but NOT expensive.
Thanks
