I managed to pick up some Kenko extension tubes quite cheap. Been having a play with my Sigma 24-70 on them. Not bad magnification
I think I need some general advice to make sure I'm not doing anything wrong:
1) It seems the zoom on the lens actually doesn't zoom at all any more, it just adjusts the focus distance. This right?
2) I neeeeeeeed a macro rail thingie. Any recommendations for that + tripod? Can you buy one and attach it to any tripod?
3) I'll be investing in the 100mm f2.8 soon and a flash thereafter. I'm thinking either ringflash, or general purpose flash on a long arm firing downwards just above the front element of the lens.
I'm off to take pictures of small things
