Kernal Power Critical Event - random freezing pc
28 Dec 2009
Wales
Right, hoping you guys can help as I am at the end of my tether.
I have the pc in my sig, running and AMMD 965 on an asus M4A79XTD-Evo board running windows 7 64 bit.
I continue to get random freezes/hangs which can only be resolved by a hard reset.
I am on my fourth set of ddr3 so would like to think that isnt the problem. I am using the high power setting in windows. And i have just now disabled cool'n'quiet to see if that helps. I ahve reinstalled win 7 so its relatively clean.
I have checked the event viewer and getting the following:
A kernal-power event event id 41 task category 63
- System
- Provider
[ Name] Microsoft-Windows-Kernel-Power
[ Guid] {331C3B3A-2005-44C2-AC5E-77220C37D6B4}
EventID 41
Version 2
Level 1
Task 63
Opcode 0
Keywords 0x8000000000000002
- TimeCreated
[ SystemTime] 2010-06-10T13:27:02.076818500Z
EventRecordID 15703
Correlation
- Execution
[ ProcessID] 4
[ ThreadID] 8
Channel System
Computer Andrew-PC
- Security
[ UserID] S-1-5-18
- EventData
BugcheckCode 0
BugcheckParameter1 0x0
BugcheckParameter2 0x0
BugcheckParameter3 0x0
BugcheckParameter4 0x0
SleepInProgress false
PowerButtonTimestamp 0
My eternal gratitude to anyone who can help?
I have tried now also turning on ecc in the memory options to see if that helps. Sigh I wish diagnosing errors was not so hit and miss.
Mmmm, computer jsut threw another fit. Really stumped now, anyone else had this problem?
