kernel power event 41 problems
10 Mar 2012
hi guys have had this problem for about 5 months now
still cannot pinpoint the problem its restarts by itself every 3-7 hours
my specs
amd 955 be
windows 7
asrock 970 extreme 3 r2.0
corsair 4 gb dominator model number tw3x4g1600c9d
xfx 650w gtx480
now today i have looked on the asrock website and found that the ram i have is not on the list for the memory support list could this be the problem that the ram is not compatible but if it is not compatible would it not even boot up
regards connor
You need to look for any events that happened prior to the shutdown. Event 41, as posted above, is the event generated upon restart from an unexpected power loss/shutdown.
The events that happened prior to the shutdown are the ones that will give you some clues. It could be driver related, however it's more likely to be power related, though this is not to say that it's the power supply itself at fault. It could be the power stage of your motherboard or GPU that's faulty.
thanks for the reply the psu is only 8 months old the error iam having at the same time is
event 7026 failed to load boot i will get the full error specs when i have finished work
event 7026 service manager
the following boot-start system-start-drivers failed to load hssdrv6
thats the error i get with the kernel power event 41 task 63
