kettle leads + psu
7 Sep 2008
hi is there such a thing as a kettle lead being damaged due to a faulty PSU?
today my newly built home PC no longer powers up (new PC but the PSU is 12 year old cosair one)
I turned the power on and nothing happens, turned plug off and on
then I thought I'd try a different kettle lead like the one from the monitor, when i put it inside the PC I heard a little spark and then nothing
that same lead no longer works on my monitor - I think the PSU is dead and damaging the kettle leads is that such a thing?
Could be blowing the fuses on the leads.
The psu right? Well on one of the damaged kettle leads maybe if I replaced the fuse and it works on a monitor then yep that confirms the PSU needs to be replaced
such a shame how long are they supposed to last? mind u been 12 years or so
12 years is a good innings, the best PSU's can have 10 year warranties.
Can try changing the fuse yeah.
Dont keep trying the PSU, it might damage the pc. :cry:
I couldnt get hold of a GPU and im using the same one from 10 years or so back
just general pc etc for now
but id imagine i will need a bit of power in the future in case i want to game....
its an ryzen 3600 with 16gb of ram.
yep just found 2 x spare kettle leads and the monitor works
I will double test by replacing the fuses on the old kettle leads but I couldnt find any fuses here
saved £30 in kettle leads today result!
well tis "prime" day today got any suggestions on a potential PSU? Don't want to break my bank account balance though. need something very quiet.
No, that's against the rules. There's only a couple anyway & I wouldn't recommend either. Go for one of the PSU's @EsaT suggested.
Same happened to my backup PC a couple of weeks ago, blew the PSU and it took out the kettle lead presumably due to the fuse.
Bin the PSU obviously something amiss.
