Need a little help if anyone can advise.
I have a piece of software on a pc which generates key codes for one of our pieces of software. I need to transfer the key code software onto another machine but do not have the installation disk. If I copy the program files folder across from the old machine ans run the software I get a
"Your License information is invalid"
I have looked everywhere on the working machine but can't find this license code file. The only files in the program files directory are the key generator and a text file. Is there anyway to find where this license file is when I run the software on the old machine? I have searched for files last accessed but nothing shows up apart from the exe.
Does anyone have any ideas?
Thanks!
Thanks!
