Keyboard advice.
3 May 2012
Wetherspoons
Hi all,
I have a mechanical keyboard a https://www.ttesports.com/productpage.aspx?p=130&g=ftr#.Y38IjX3P0_Y
Which I believe is blue switch. Anyway I have had it for a long time (over 5 years for sure) and basically I somewhat ruined it trying to clean it a couple of months back, some of the keys are not working very well, it was also at the time one of the the very budget end of mechanical boards i could find.
I quite like blue "clicky" keys, even for gaming which is what I basically use my PC for even though lots of internet results suggest red are better for games. To be fair, the keys on this one are not that clicky anyway, although I would say this mechanical keyboard is pretty awful for typing on. I'd probably go blue switches again.
Im interested in a few:
Got RGB , which to be fair, isnt such a requirement, is handy if the keys light up though. At £144 is a fair chunk of cash though.
This one is cheaper (although out of stock) and actually prefer the aestetic retro (ish) look but dont think the keys light up.
But I dunno...so hard with keyboards one of those things you really could do with seeing and testing in person.
Any suggestions or are the above good choices?
