Keyboard and Mouse for Quest 3, connected to remote PC?
23 Mar 2005
I posted this over on the network sub, but am hoping someone here might have an alternative answer from the Quest perspective.
I am currently using my Quest 3 in the lounge to access my gaming PC in the garage. The quest connects to a wireless access point in the lounge (wifi 6), and the PC connects to the same access point via a 15m Cat 6 ethernet cable that runs between the garage and the lounge. Playing VR games works flawlessly (been enjoying HL: Alyx in blissful, wireless freedom!)
However, I want to be able to play non-VR games, using the Quest as a virtual screen, and need to be able to use a keyboard and mouse. Essentially I'll have a huge virtual cinema screen infront of me displaying games running on the garage PC. The problem I have is I cannot get the keyboard and mouse to work with the remote PC.
Things I have tried:
  • Plugging the (logitech) KB/Mouse dongle into the quest directly (works on the quest, but won't interact with the remote PC)
  • Using an unpowered USB-ethernet adapter: one each side of the external cable. Doesn't work across the external cable.
  • Using a powered USB-ethernet adapter (4 port transmit/receive unit) - again, does not work across the external cable - rated for 60m of ethernet, I'm using less that 15m.
I have tried using Virtual Desktop, Quest Remote Desktop, and Airlink - none of them will pass through the KB/Mouse.
I am trying to troubleshoot the external cables - both of them have no issues with passing network signals (internet works flawlessly, and the Quest runs at full speed across it)
Is there a different way to use the KB/Mouse to remotely control to PC?
You need something like a KVM extender that works over an ethernet cable. They are expensive though. They come with a transmitter and receiver.
This is effectively what I have with the powered USB-ethernet adapters (just not adding the monitor option which I don't need). The difficulty is that I'm not controlling one PC from another, which almost all of the solutions assume you will be doing. There is no reason a usb extender shouldn't work... but here I am ... :p
It's alive! I have no idea why, but everything is working exactly as it should! If anyone finds this in future, once working, powered usb-ethernet adapters are definitely the way to go over longer distances. Waaaaaay simpler than the various usb over IP software option I explored - guess it's still true: "nothing beats a long cable"
Can you help me with how you did it? Was VirtualHere the solution? Can I find a description or video somewhere on how to set it up? I have a similar problem. The difference is that I have a PC much further away that I want to control with a mouse. Therefore cable connection is not an option.
I just bypassed the whole software issue completely, and went with a purely hardware solution (always the best option!) May not help you with your setup, unfortunately, but I have simply run long cables. As above:
Mouse -> Dongle -> powered USB-to-ethernet adapter -> 20m Cat 6 cable -> other half of the USB-ethernet adapter -> USB cable -> plugged into PC. No software involved, so no headache :)
Could you link the USB adapters?
Having an identical issue to yours but I can't see how the adapters I'm finding will help! Luckily my outbuilding has a wired ethernet to the house.
im guessing its something like :​
USB 2.0 Extender 4-Port USB Extender Over Cat5e Cat6 USB RJ45 LAN Extension 5V Low-Power Consumption USB Extender Ethernet Work Sync Windows MacOS Android Linux No Driver EX50USB​
