Keyboard for Gaming but also Work
19 Oct 2002
Maidenhead
Hi,
I am considering getting one of the Corsair RGB keyboards and was wondering whether any of you use Brown Switches for Gaming and if so, how are they?
I mostly play FPS games like TF2
Cheers
I use browns for gaming (not in a Corsair keyboard though), and they're fine. Nice and clacky for typing, but responsive enough for gaming. Currently playing through Borderlands:TPS with no problems :)
I use a K70 with browns for gaming and as above it's fine, I play different FPS's from BFBC2 to Arma 3. I have O-rings fitted to help with the noise..
browns are my keys of choice and out of all of them they are the ones i most prefer. However mechanical keys are very much personal preference so it really is best for you to try different keys to decide if you are planning on hefting out a lot for a keyboard
Thanks,
I used to have a mechanical keyboard until it broke, then i bought this nasty flat thing. It was rather noisy but very responsive... really miss it!
Anyway thanks, I will give Brown's a go ;)
