Keyboard Help
21 Feb 2004
Hi,
Just picked up a Lenovo laptop.
The number 2 key has the "at" sign on it, whilst the " sign is adjacent to the enter key, were the @ key typically is.
The region, keyboard etc is all set to UK, but when I press shift and 2, it gives me the " sign, and when I press the " key it gives me the @ sign.
Quite annoying but not life threatening.
Anyway I can chase the buttons to reflect what they are displaying please?
Thanks
Language is set to USA. You haven't checked properly. Or your keyboard is possessed. Or possibly buggered.
*Edit* Just re-read! The post below mine has nailed it. Ignore my tomfoolery.
You have a US layout. If you want the key presses to reflect what you press, you need to set your language to US.
The Macbook does this too. You have a UK layout. But it still has the " and @ in US ANSI layout with a slim ISO enter key.
Superb, thank you
