Keyboard key loose.
the easiest way is to pop off the cap of a 2nd key, look at how the mechanism is assembled and put it back together
once it's all together, it should pop back to into place with a firm push (when lined up on the keyboard)
When the key came off the actual clip was attached to the key so I had to remove it as I read it needs assembling underneath, I really don't want to take off another as I am afraid I won't be able to get them back on
reassemble the clip onto the keyboard (if you remember how it went together), then press the key cap onto the clip. (it generally how I fit keys back onto laptop keyboards)
