- 1 Jun 2012
- UK
Hey, starting to have a small issue with input lag from keyboard, it started while i was playing wow, just felt like when i was pressing the keys my character was lagging slightly but my ping was fine, then in chat, i would type a way and it would hang then suddenly put in 3-4 words, type normally then hang and 3-4 words. Now it is doing it in world of tanks and chrome and i think microsoft word as well.
I'm check if its the keyboard when my flatmate gets up, test it on his pc, maybe the buffer on the keyboard isn't broken or something. Also changed the roll over setting, still no change.
What i'm worried about is that it's like a key logger or some other malware.
The only thing i have changed in the last week or 2 is update the bios, reinstall audio drivers and change to a pair of Astro A40s with the mix amp, so sound is now running through the optical port.
Edit: tech specs
i7 3770k
gigabyte z77-d3h with latest beta bios
16gb ram
amd 7870
samsung 830 ssd
2tb samsung sshd
xigmatech powersupply
Corsair k95 keyboard
Edit: tech specs
i7 3770k
16gb ram
amd 7870
samsung 830 ssd
2tb samsung sshd
